I have a problem understanding which resistors set input impedance of an instrumentation amplifier. What is the input impedance of the circuit given and what is the purpose of R250 (10k to GND)?
R250 is needed to allow natural bias currents from the op-amp inputs to flow to local 0 volts. If it were not there, the inputs would float and likely cause common-mode input range problems.
The differential input impedance (S2A and S2B in current positions) is R163 + R164 = 1022 Ω. This increases by 28 kΩ when S2A and S2B are changed over.
