Background: Hello, I am a first timer trying to finish this PCB redesign. I am in dire need as an intern who has no clue what they are doing but is having fun learning.
I have all my schematics working but I need to figure out a solution for this connector scenario in the picture. Someone who is an utter genius hopefully can innovate for me here :D
I need a wire-to-board connector that clamps/secures itself onto the top board's male or female connector somehow.
That male or female connector is connected to the top layer's circuit and then passes it through to the connector below it on the bottom layer.
The bottom board's connector should be able to work without the top layer board by also being able to be used by the same wire-to-board connector that can lock in somehow. (The wire-to-board connection that can snap into top and bottom basically.)
The bottom connectors share the same connection pins and pass it on to the bottom layers circuit. The bottom can work independently or with the top board.
These need to be 10+ pin solutions ideally.
I don't know if this is even possible.
In the left side of the image, the idea is that the two connectors on the top side and bottom side of the top board would be surface mounted and share the same pads or something, (I don't know how to do that, but will cross that bridge when we get there.)
On the right side of the image it's a female with super long pins that then connects to the female connector below.
If any of you can figure this out, I have been at it for a few days, thanks!
