I need help in identifying a SMD component which has the following marking code "FPR (with top bar and dot) 595" which is a 10 pin component 4 pins to the left and right and 2 pins on the top and bottom and it's present in the power line. Most likely Voltage detector but not sure:
Attaching the schematic for your reference:
