I want to drive an RGB-LED with 3 PT4115 ICs. But as soon as a single and short signal is applied to PWM_3.3V, the voltage wont drop in time, so LED starts to dim. You can see the Voltage of the LED in this picture:
When duty is about half of the cycle:
I already changed the inductor from 47uH to 22uH, and tried PWM frequencies from 500Hz to 2 Khz, but that didn't change anything. What could be the problem?
This is the schematic of a single channel:
Thank you in advance :)
