Is there any way to get -12 V (DC) using only:
- +12 V DC
- Ground
- OPAMPs
- Resistors
- Capacitors
- Inductors
- Diodes
To test: Connect a DMM's ground lead to the wire you've labeled "GND". Connect the positive lead to the wire you've labeled "-12V". The display will read -12 volts.
Of course, this won't work if you've got any other signals referenced to the original ground, so it's rather tongue-in-cheek. Just wanted to point it out in case it wasn't obvious.
More seriously, my solution would be a charge pump driven by an RC oscillator. Without transistors, this will limit you to the output current of your opamps. On further consideration, it might not be possible due to the problem of bootstrapping your opamp power supplies.
Of course, you can make nearly anything with all of those. Depending on your current/power requirements, you are looking at one of the following switching supplies:
Normally one would use a dedicated SMPS controller, with internal oscillator, and gate driver along with a handful of transistors to implement these, but apparently you can't use them. You must design a harmonic oscillator out of inductors and capacitors, then buffer and clean up (make square) this signal with op amps. With this chopper signal you can implement either of the above SMPSs as well as stabilize the LC oscillator (it will die).
LM7660 or equivalent *7660 part.
Have a look how it works, it is fairly easy to implement with an op-amp and a few external components.
I'm not going to do all your homework, though.
