Two weeks ago, I picked the wrong tub of flux from my toolbox and used it for making a 9VAC -> 5VDC adapter. I fluxed all the components and soldered it down before realising I was using PLUMBING flux!
The solder pads are all still intact and I've tested the conductivity of the leads of all my parts; they are all intact.
So to summarize,
How should I remove the flux after desoldering in such a way that I can reuse the PCB?
and
I may have used small amounts on other repairs in the past (all of them my own personal projects, none for others). Will I have to worry too much about these?
The flux is labeled as "alpha metals" brand "soldering paste flux".
