I know that bits per second and hertz are two different units. This question will help me in designing an oscilloscope with proper ADC sampling frequency for viewing communication protocols.
Just imagine a communication protocol(eg: I2C) which has a data rate of 1Mbps. As per the protocol, there are different fields where we can keep data, address etc. But I am currently assuming that each bits in this protocol is toggling one after the other. Then this looks like a square wave.
In a square wave, the fist half will high(Logic 1) and the second half will be low(Logic 0) or vice versa. So in one cycle we have two bits. As per this visualisation 1Hz i.e 1 cycle/sec is equivalent to 2bits/sec(or 2bps).
Similarly for 1Mbps data rate, there will be 1000000 bits per second. If we assume each bit is inverse of the other(i.e they toggle like a square wave) and as per our calculation, 2bits will be present in one cycle of square wave, then 1000000 bits per second = 500000Hz (1000000bps /2 bits in one cycle). So 1Mbps is equivalent to 500kHz square wave.
Is my visualisation correct(I converted bits per second to hertz)?
I want to make a USB oscilloscope in which I want to select a proper sampling frequency for the ADC. So in this case if I assume 1Mbps as 500kHz, then for a good signal display(signal reconstruction based on the ADC samples), sampling should be done at 10 times the signal frequency i.e 5Mega samples per second (500kHz *10 = 5MHz)
Is this calculation correct ?
Also does this mean that I can view this communication protocol's voltage levels clearly on a oscilloscope having bandwidth of 5MHz (500kHz *10)?
If all you want to do is see the voltage levels of the signal then your analysis is correct. Also, in the case of a true square wave (rather than a stream of digital pulses) you will be able to determine the fundamental frequency, according to Shannon and Nyquist. However, a square wave has significant frequency content at much higher frequencies...at least to 11 times the fundamental for practical purposes.
Unfortunately, you will be missing a lot of the information that is critical for digital signalling protocols. You won't be able to determine the actual width of a pulse very accurately. It will also be very difficult to observe the relationships between signals, such as clock and data, that are absolutely vital when debugging serial protocols. To be useful for debugging you must sample at a much higher rate, and you should be able to trigger the scope on the edges of one signal while sampling another signal simultaneously.
My opinion is that a good scope would be sampling at about 20 times the data rate.
EDIT: For serial communications the pulse width, in time, for each bit is a very important parameter. If your data rate is 1Mbps then you expect the pulse width to be 1\$\mu\$s, but if you only sample that signal at 5MHz then your pulse width measurements will be \$\pm\$0.1\$\mu\$s which is pretty rough. More important in my mind are setup and hold measurements. You want to know how long the data signal is stable before a clock edge and how long it remains valid after a clock edge. Specifications for setup and hold may be tens of nanoseconds for a 1Mbps data rate, and it will be very difficult to observe these when sampling every 200ns.
For debugging serial communications the instrument you really want is a logic analyzer. These devices can sample data at very high frequencies but they don't try to measure the actual voltage of the signal, only whether it is a valid logic 1 or 0. They also have other capabilities that are made possible by treating the inputs as digital data rather than analog voltages.
  • \$\begingroup\$ Could you please make it clear why there will be lots of information missing that is critical for digital signalling protocols ? Is it because that the square wave at higher frequency has frequency content of 11 times the fundamental ? \$\endgroup\$
    – robomon
    Dec 21, 2013 at 14:49
  • \$\begingroup\$ Yes, a perfect square wave has infinitely many frequencies. You need to choose what is enough for the use case. \$\endgroup\$ Aug 29, 2018 at 11:33
