I'm thinking of making a low power FM transmitter. Here's a diagram.
It seems an absolute pull range of a VCXO will limit the modulation index. Is there possibly a way to extend it?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityIt seems an absolute pull range of a VCXO will limit the modulation index. Is there possibly a way to extend it?
You could use a colpitts oscillator and varactor - you could "wrap" around it a PLL so that centre-frequency stability is as good as a reference crystal. I've done this a few times on applications ranging from 80 MHz to 400 MHz and got FM deviations of +/- 5MHz no problem and data rates of up to 15 MBpsec.
EDIT
Here's a PLL that takes 6mA and works upto centre frequencies of 400MHz: -
You need a small MCU for setting up the division ratio to make lock plus a simple varactor controlled colpitts will do the trick. Or, try the LTC 6905: -
I particularly like this device because it's really simple and doesn't go belly-up on large G-forces (unlike cheap xtals)
You are correct. The pull range of the VCXO will limit the modulation index. A VCXO is not a good choice for use here.
There are many other types of VCO's that have wider pull range than a VCXO that you might use instead.
