44
Just now I realized that the I2C data and clock lines (SDA and SCL) must have pullup resistors.
Well, I've built a couple of clocks using the DS1307 RTC (see datasheet) according to the schematic below. Notice that I have omitted both pullup resistors.
Schematic of my clock without pullup resistors on I2C lines
Both clocks work fine, one of them is working for more than 3 months now. How is that possible? In any case, I wanted to know:
  1. What happens when the I2C pullups are omitted?
  2. Is the lack of pullups likely to damage any of those two ICs in my board?
I'm after answers that address my specific case of connecting ATmega328P to a DS1307 RTC like in the schematics I provided, but if the question doesn't get too broad, it would be helpful to know what happens when the pullups are omitted in general, i.e., in other scenarios of I2C operation.
PS. I did search the Net to find the answer, but could just find articles about dimensioning the pullups.
Update: I'm using Arduino IDE 1.03 and my firmware handles the RTC using the DS1307RTC Arduino lib (through its functions RTC.read() and RTC.write()). That lib in turn uses Wire.h to talk to the RTC.
Update 2: Below are a series of scope shots I took to help explain how the I2C is working without the external pullups.
Scope shot 1 Scope shot 2
Update 3 (after I2C pullups added): Below is another series of scope shots I took after adding proper (4K7) pullup resistors to the I2C lines (on the same board). Rise times dropped from about 5 µs to 290 ns. I2C is much happier now.
Scope shot 3 Scope shot 4
    \$\begingroup\$ Does your code disable the pullups on those pins? \$\endgroup\$ Commented Mar 12, 2014 at 3:38
  • \$\begingroup\$ @IgnacioVazquez-Abrams There's no direct mention to SDA and SCD pins (18 & 19) in my code. I handle the RTC using the DS1307RTC lib Arduino lib and its functions RTC.read() and RTC.write(). \$\endgroup\$
    – Ricardo
    Commented Mar 12, 2014 at 3:51
  • \$\begingroup\$ That lib in turn uses Wire.h to talk to the RTC. \$\endgroup\$
    – Ricardo
    Commented Mar 12, 2014 at 3:54
  • 5
    \$\begingroup\$ Yeah, definitely using internal pullups. Note the curves instead of sharp edges. \$\endgroup\$ Commented Mar 13, 2014 at 0:00
7 Answers 7
40
1) What happens when the I2C pullups are omitted?
There will be no communication on the I2C bus. At all. The MCU will not be able to generate the I2C start condition. The MCU will not be able to transmit the I2C address.
Wondering why it worked for 3 months? Read on.
2) The lack of pullups is likely to damage any of those two ICs in my board?
Probably not. In this particular case (MCU, RTC, nothing else), definitely not.
3) Why was the MCU able to communicate with the I2C slave device in the first place? I2C requires pull-up resistors. But they weren't included in the schematic.
Probably, you have internal pull-ups enabled on the ATmega. From what I've read1, ATmega have 20kΩ internal pull-ups, which can be enabled or disabled from the firmware. 20kΩ is way too weak for the I2C pull-up. But if the bus has a low capacitance (physically small) and communication is slow enough, then 20kΩ can still make the bus work. However, this is not a good reliable design, compared to using discrete pull-up resistors.
1Not an ATmega guy myself.
update: In response I2C waveforms, which were added to the O.P.
The waveforms in the O.P. have a very long rise time constant. Here's what I2C waveforms usually look like
PIC18F4550, Vcc=+5V, 2.2kΩ pull ups. Waveform shows SCL. The rise time on SDA is about the same. The physical size of the bus is moderate: 2 slave devices, PCB length ≈100mm.
  • \$\begingroup\$ Thanks for your answer! Yes, the ATmega has pullups that must be enabled in my case. I'll double check the code and the libs I'm using and also put the board through the scope. I hope that will clear things a bit. \$\endgroup\$
    – Ricardo
    Commented Mar 12, 2014 at 4:09
    \$\begingroup\$ You may want to double check with with the datasheet of your slave device first. If I remember right, the pullups on the ATMega's can be anywhere from 30k-60k (it depends on Vcc, temperature, and a number of other factors; you can't really depend on them for a reliable resistance). You want to make sure you're sending enough current to the slave to ensure a proper logic 1. If the resistance is too large, your slave device won't get enough current and you'll be in the same spot you're in now. \$\endgroup\$ Commented Mar 12, 2014 at 4:47
  • 6
    \$\begingroup\$ @audiFanatic +1. BTW, IMO, including pull-up resistors into the breakout boards and installing them by default is an error. Imagine what happens if somebody has multiple breakout boards on one I2C bus. Each pull-up is usually 2.2kΩ or so. The pull-up resistors on all of the break out boards appear in parallel. Combined pull-up becomes too stiff for I2C. [More about this potential problem here and here.] \$\endgroup\$ Commented Mar 12, 2014 at 5:03
    \$\begingroup\$ @Ricardo That's not a happy I2C bus on your scope shots [first set of scope shots in the O.P.]. I've added a scope shot to my answer too. \$\endgroup\$ Commented Mar 12, 2014 at 22:59
    \$\begingroup\$ This article has some waveforms of good and bad i2c signals: dsscircuits.com/index.php/articles/… \$\endgroup\$
    – ford
    Commented Mar 13, 2014 at 4:18
22
The library you use, and the libraries it depends on (Wire), enable the internal pull-ups of the ATMega. These are weak pull-ups, and in normal use, supplement any external pull-ups (two resistors in parallel). Due to the relatively high resistance of 20k to 70k, they do not cause much if any issues with external ones in use.
Now without external resistors, the weak internal pull-ups are the only thing driving the line high. Depending on your board layout, the speed of your i2c line, how often you access it, external interference, etc, they might work, they might not. You lucked out. You do have pull-ups, just not ones you expected.
Even without the internal pull-ups, a lack of any pull-ups will not damage either IC. The internal build of i2c device SCl and SDA lines are like NPN transistors. They are Open Collectors, essentially current controlled/switched diodes.
The last thing to note though, having the internal pull-ups on, when your ATMega is at 5v, and the i2c device is a 3.3v only device, can cause issues. Or if you have the internal pull-ups on, and external resistors connected to a 3.3v or other voltage, can also cause issues. Essentially, it's an intentionally ignored bug in the Wire library.
  • 4
    \$\begingroup\$ +1 - You do have pull-ups, just not ones you expected. - I guess you nailed it. Thanks! \$\endgroup\$
    – Ricardo
    Commented Mar 12, 2014 at 4:49
  • \$\begingroup\$ Just so you know I've added a few scope shots to help clarify what's going on with my setup. \$\endgroup\$
    – Ricardo
    Commented Mar 12, 2014 at 22:30
    \$\begingroup\$ @Ricardo yep, seeing those, at 33khz. A third of the lowest i2c spec'ed speed, and the signal is still very bad. At 100khz or 400khz, you wouldn't have working communication. Great thing though, is many i2c devices work at a fraction of the max speeds. Just remember, the internal pullups can be up to 70k ohm, a typical i2c resistor is 4.7k \$\endgroup\$
    – Passerby
    Commented Mar 13, 2014 at 4:16
9
Generally you will need to have the pullup resistors for an I2C interface circuit. If the interface is truly a full spec I2C on both ends of the wires then the signal lines without the resistors will never be able to go to the high level. They may remain low or go to some intermediate level determined by the leakage current in the parts at each end. The reason for this is because true I2C is an open drain bus.
Some devices may actually have on-chip pullup resistors in the 20K to 100K ohm range just to hold the interface pins at a high inactive level when the I2C interface on the part is not in use. For simple and short interfaces these pullup resistors may be just enough to provide the current needed to pull the lines high while clocks and/or data is being signaled.
It is hard to tell from your schematic but in some instances I2C interfaces are implemented using general purpose I/O port pins and then bit banged in software. Sometimes the implementer may not operate the I/O pins in this configuration using an open drain methodology and this may play a factor on why an interface without pullup resistors may seem to work.
At the end of the day you probably owe it to yourself to check out the signalling on one of your earlier clocks using an oscilloscope to see if the 1's and 0's on the interface are working within spec voltage levels. Then you will know for sure whether you were just incredibly lucky with that implementation or if one of the factors that I mentioned above is at play.
What happens when the I2C pullups are ommited?
Most likely, the I2C bus will simply not work.
Most likely not.
Your I2C lines will not work at all. If I'm not mistaken, I2C just asserts low signals, but does not return them to back to a high state, which is why you need those resistors.
Any lack of pull-ups should not damage any IC.
    \$\begingroup\$ I2C pins are open drain. \$\endgroup\$
    – Matt Young
    Commented Mar 12, 2014 at 3:40
I2C is a TTL-logic protocol; so your data and clock lines are open-drain. In other words, the I2C hardware can only drive these lines low; they are left floating when not a zero. That's where the pull-up resistors come in. This is a simplified diagram, but work with me for a second.
As you can see; the pull-up resistor is needed to ensure a logic 1 is seen at the output when the TTL logic is not driving the output low. TTL logic cannot drive the lines high as I already mentioned. If this were not present, the output would be left floating and it's unpredictable what you may see at the output (for all you know, your microwave or the intestinal dysfunctions of your co-workers caused by a certain sugar-free gummy bear could cause the value to fluctuate).
Now, if you were to implement I2C in software with a microcontroller, this would likely not be too much of an issue as it will most likely be using CMOS logic, which can drive outputs both high or low.
    \$\begingroup\$ Glad it helped. \$\endgroup\$ Commented Mar 12, 2014 at 4:35
    \$\begingroup\$ Whether the devices use TTL or CMOS logic doesn' matter - normal TTL and normal CMOS outputs will pull signal both up and down. The I2C signals are either open-collector TTL, or (more likely) open-drain CMOS - in both cases, the transistor that would pull the signal high is missing from the output stage of the source, so pull-up resistors are required to pull the signals high. It is possible that the microcontroller has internal pull-ups on those pint. \$\endgroup\$ Commented Mar 12, 2014 at 6:29
  • 4
    \$\begingroup\$ -1 As Peter Bennett said, a lot of this answer is just wrong. Calling TTL signals "open-drain" is the giveaway. \$\endgroup\$
    – Joe Hass
    Commented Mar 12, 2014 at 10:54
    \$\begingroup\$ Note that there are advantages to doing I2C with TTL, namely that you often don't need level translators to handle components with different supply voltages attached to the same bus. Simply setting the pullup voltage to the highest accepting input voltage of the lowest voltage chip is many times sufficient with TTL input stages. On CMOS, that wouldn't work. \$\endgroup\$
    – Ben Voigt
    Commented Mar 12, 2014 at 15:26
    \$\begingroup\$ @BenVoigt: No - calling the "requires a pull-up resistor" configuration "TTL" is wrong, as this arrangement can be made with either CMOS or TTL, and the DS1307 is a CMOS part. The Maxim datasheet clearly states that the outputs are open drain,and the block diagram shows a FET for one output. \$\endgroup\$ Commented Mar 12, 2014 at 16:04
When I bit bang I2C with a micro as the master which supplies the clock then I have been able to drive the SCL without pullup.
However, SDA does need to be OC with pullup so the slave device can pull down and respond properly.
Regards
