I bought a 115 to 15V toroidal transformer.The turns ratio of this should be (115/15)=7.66 ideally.
Now the problem I'm facing is that upon wiring it I'm getting a calculated turns ratio of 6.97, which doesn't match the datasheet.
I plugged it into my wall outlet and measured 122 V with my voltmeter coming into the primary side. On the secondary of the transformer I am getting an output voltage of 17.5 V.
This give me: (122/17.5)=6.97 turns ratio.
Why is this? The toroidal transformer also had this wound plastic which encircled the coils and I cut that off. Could that be the reason why this is happening or is it just how things in the real world work?
