Based on another question recently asked, this package is very common, used in high current LED applications (0.5W ~ 3W). The package includes the led chip, lens, heatsinking, but can vary in light radiation patterns. Very common, they have been around for years if not decade. But I have never found a common package name, unlike other led types (5mm, 3mm, Straw Hat, 1206, 0805, etc). Is there a common name, or even a JEDEC or similar standard to standardize this type of package?
Front view Back view
The package is called by different trade names by companies,
Lumileds Corp calls them "Barracuda",
while
Osram Opto. calls them "Dragon".
led-package-barracuda-lumileds
The important feature of the package is a heat-conducting metal center, the "heatsink slug", that can be soldered onto a larger heatsink below:
For details and source, see the chapter on LED packaging of the somewhat-retired LED-related website Light-Emitting-Diodes-dot-org - (note different domain).
See the bottom-left image: Chapter 11: Packaging - Fig 11.5.
A possible reason for not having a clear type code for this package could be that it was not actually a LED package, but just a more generic heatsink-with-extra-plastic-lens.
*Barracuda was, at least initially, actually referring to the type of LED die itself, not the package. See ledmuseum.candlepower.us and Philips LED Update - page 8
  • \$\begingroup\$ Nice find. It also goes with the name convention for piranha led packages (Figure B & C in link). \$\endgroup\$
    – Passerby
    Commented Jul 30, 2014 at 2:01
  • \$\begingroup\$ Where did that term "heatsink plug" come from? is it "slug"? \$\endgroup\$ Commented Jul 30, 2014 at 2:03
  • \$\begingroup\$ @Passerby But then, the "heatsink slug" is just that piece of metal, drawn in pink. (slug means something like blob). \$\endgroup\$ Commented Jul 30, 2014 at 2:07
  • \$\begingroup\$ Figure 11.5 refers to label d as heatsink plug, and then explains that Barricuda is the trade name for that package by Lumileds. Same as the Piranha being refered to simply as b, low profile. \$\endgroup\$
    – Passerby
    Commented Jul 30, 2014 at 2:16
  • \$\begingroup\$ Oops, put plug instead of slug. fixed. \$\endgroup\$
    – Passerby
They are usually referred to as "2-SMD, Gull Wing". I haven't seen a standard refer to this type of package.
"Gull wing" actually refers to the shape of the leads. It is a general term that applies to almost all smt packages that have leads bent towards the outside of the pack, such as QFP.
  • \$\begingroup\$ Gull wing referring to the lead shape though, as opposed to jlead or right-angle. \$\endgroup\$
    – Passerby
    Commented Jul 19, 2014 at 23:09
  • \$\begingroup\$ @Passerby: yeah. It is a very generic name that doesn't really mean anything. But that is what all of them are using to describe it. Unless it's a star shaped module so they say "star shape"... \$\endgroup\$
    – Evan
    Commented Jul 19, 2014 at 23:17
