I am trying to achieve a simple SPI communication of 16-bit data from a PIC24FJ64GA002 to another of the same microcontroller. By following the data sheet to the word, I wrote the transmitter and receiver code as below,
Transmitter:
unsigned int i = 0;
void main()
RPOR2bits.RP4R = 7; // Data out through Peripheral Pin 4
RPOR2bits.RP5R = 8; // Clock out through Peripheral Pin 5
SPI1CON1bits.MODE16 = 1; //16 bit mode
SPI1CON1bits.MSTEN = 1; // Master enable
SPI1CON1bits.SSEN = 0; //No slave selection
SPI1STATbits.SPIROV = 0; //Receiver Overflow cleared as told in datasheet
SPI1STATbits.SPIEN = 1; //SPI is enabled
while (1)
while (SPI1STATbits.SPITBF); //Waiting for any transmission to complete
SPI1BUF = i; // Data is written
i++
Receiver:
unsigned int i;
void main()
RPINR20bits.SDI1R = 0; //Data in through Peripheral pin 0
RPINR20bits.SCK1R = 2; //Clock in through Peripheral pin 2
AD1PCFG = 0xFFFF;
TRISA = 0x0000;
SPI1CON1bits.MSTEN = 0; // Slave mode
SPI1CON1bits.SMP = 0; //Must be cleared in slave mode as told in datasheet
SPI1CON1bits.DISSDO = 1; //Receiver only receives data
while (1)
while (!SPI1STATbits.SPIRBF); //waiting for receive to complete
LATA = SPI1BUF; // pushing Received data onto A
The transmitter seems to be transmitting the data (clock and data lines show expected cycles), but for some reason the receiver does not receive the data and push it onto A terminals.
The configuration settings for both microcontrollers are:
Primary Oscillator Select: Primary Oscillator Disabled
I2c1 Pin Location Select: Use default SCL 1/SDA 1 pins
IOLOCK Protection: Disabled
OSCO Pin Configuration: OSCO functions as port I/O
Clock Switching and Monitor: Clock switching is enabled, Fail-safe Clock Monitor is enabled
Oscillator Select: Fast RC Oscillator (FRC)
Sec Oscillator Select: Default Secondary Oscillator (SOSC)
Wake-up timer Select: Legacy Wake-up Timer
Internal External Switch Over Mode: Disabled
External Watchdog Timer Postscaler: 1:32,768
WDT Prescalar: Prescaler ratio of 1:128
Watchdog Timer Window: Disabled
Watchdog Timer Enable: Disabled
Comm Channel Select: Emulator EMUC1/EMUD1 pins are shared with PGC1/PGD1
Background Debug: Disabled
General Code Segment Write Protect: Disabled
General Code Segment Code Protect: Disabled
JTAG Port Enable: Disabled
The only two connections are the Clock and data lines from the respective peripheral pins. What is the problem here and how to receive the data?
It seems impossible that this actually works, has anybody ever achieved this?
