I am buying a rotary switch, and I have found these terms:
2 x Off/(On)
and
2 x Off/On
Could you please explain me the difference?
edit:
example of a switch with Off/(On) specification enter image description here
(originally from this page)
  • \$\begingroup\$ There probably isn't one, but no way to know without links to the datasheets. \$\endgroup\$
    – Matt Young
    Commented Dec 23, 2014 at 21:24
  • \$\begingroup\$ Please post links to datasheets where you have seen these terms. \$\endgroup\$ Commented Dec 23, 2014 at 21:48
  • \$\begingroup\$ It is in danish: conradelektronik.dk/websale8/… \$\endgroup\$ Commented Dec 24, 2014 at 11:30
  • \$\begingroup\$ And: conradelektronik.dk/… \$\endgroup\$ Commented Dec 24, 2014 at 11:32
Usually positions in parenthesis are momentary positions.
So a switch that is Off/(On) is a single throw switch that is momentary switch. It will not stay in the on position, but will spring back to the off position. A switch that is Off/On will stay in either position.
Sounds like the first one's a SPDT spring-loaded single-side-stable OFF-momentary ON switch, while the second one is just a vanilla DPST ON-OFF switch.
