i am trying to make a sine wave generator. the Bubba oscillator circuit given below should produce 53 Hz. according to the text book " Op-AMP for every one", the circuit should have gain = 4, and the phase shift of 180 degrees. the values of capacitors and resistors are selected to produce 53Hz signal. everything in the circuit looks just fine to me. but when I simulate it on proteus, it has no output. what is wrong with the circuit. plus the proteus is giving some errors; pin 'V+" not modelled . screen-shot image below. this could be a simulator error, but what is the solution? In the circuit, VCC= +12volt, VEE= -12volt. Rf= 10k, Rg= 2.5k, R= 9.1k C= 0.33uF
