I would like to sniff data on an SPI bus running at a clock rate of 6 MHz. I would like to use the Bus Pirate V4 for this task. The sniffing itself is supported up to 10 MHz, the problem is getting the data on a PC in real time.
The BP page for the USB connection (V4!) says:
Max speed is 12 Mbps, but a realistic limit is 1 Mbps.
Can I just set the UART speed to 6 Mbps in Windows/Linux?
I have used a 1 Mbit baudrate before, using a 5€ China UART<>USB converter without problems. Since the BP has the USB hardware built-in, I don't see why the realistic limit would be 1 Mbit/s...
    \$\begingroup\$ somewhat related: superuser.com/a/488721 \$\endgroup\$
    – jippie
    Commented Jul 5, 2015 at 14:46
  • \$\begingroup\$ Could be related to the system clock frequency and the errors for baud rates > 1 Megabaud \$\endgroup\$
    – efox29
    Commented Jul 5, 2015 at 14:48
About the USB limit.
  • Data has to packeted into 'legal' packets according to the USB standard. This adds a couple of bytes to each of them, and lowers the speed.
  • In between, the packets have to received at the other end, checked, and confirmed with another packet, still lowering the speed.
  • The controller in the sniffer will be quite busy receiving the 'sniffed' info, and thus have less time available to attend to the USB port.
  • The USB line is also occupied with short polling packets.
That said, 1Mbps guess is probably just to be safe in all circumstances. However, I doubt that you will get to the 6Mbps (or MHz) of the SPI bus reliably.
Go made an DIY sniffer !
Another issue is "linux is slow on long word size uart" but "windofs is slow on small size uart" communication(ACM-DCM(USB-Base),size=data_length).
Yes you can set 100mbit uart speed but problem is Error ratio !
When used high speed communication device signal down to mV (millivolt) level. Offcourse you can't protect low-level signals ! Speed required buffer memory, you can't handle data on a microsecond(supercomputers can't do either, just ASIC or FPGA can handle this load).
  • \$\begingroup\$ There's no "answer" here. There are solutions to the problem using USB high speed hardware like a CY7C68013A but not really with the hardware of the question. \$\endgroup\$ Commented Sep 13, 2020 at 12:15
  • \$\begingroup\$ @ChrisStratton hello my downvoter ! \$\endgroup\$
    – dsgdfg
    Commented Sep 27, 2020 at 23:09
  • \$\begingroup\$ but just say delete it \$\endgroup\$
    – dsgdfg
    Commented Sep 27, 2020 at 23:10
