Can anyone suggest the best way to get a 12V DC electric motor (70RPM) to rotate roughly 360 degrees and then stop?
So the process would be;
  1. Power switched on.
  2. Motor rotates once, then stops.
  3. Power switched off.
  4. Repeat
Thanks in advance
  • \$\begingroup\$ Hint: Why do the windshield wiper blades keep moving to the base of the windshield after you switch them off? \$\endgroup\$
    – DJohnM
    Commented Aug 30, 2015 at 0:15
The most common method of doing what you want is to use a cam that actuates a microswitch at the desired stop point.
To do the sequence that you want, you need to add a tiny bit of smarts. This can be a couple of relays or a microcontroller.
As mentioned in the comments, most automobiles have windshield wiper motors that have such a switch mechanism built in. However, because you want the motor to operate only one full cycle upon power-up, you do need to add the smarts that I mentioned.
  • \$\begingroup\$ Thanks all for the feedback. I like the idea of a cam operating a microswitch at the desired stop point, but was unsure of how to go about it such that the microswitch wouldn't be left in the 'off' position, e.g. the process could begin again next time. I'm a complete novice here, but will investigate how to set up using the smarts mentioned. \$\endgroup\$
    – Klench
    Commented Aug 30, 2015 at 4:02
The circuit below may be one of the simplest methods, just one micro-switch and one push button.
Pushing the (normally open) push button switch energizes the motor briefly just enough to move the cam lobe off the micro-switch arm, the micro-switch connection then keeps the motor alive. The motor spins until the cam lobe comes back around to the micro-switch and turns the motor off.
You would need to be sure the size of the cam lobe is sufficient to stop the motor when the micro-switch opens, (eg. If the motor takes too long to stop there could be a problem - in which case make the cam wider).
Strap it to a rotary encoder and count the number of pulses generated. Based on the speed of the pulses you should be able to figure out how quickly you need to stop or reverse in order to end up at exactly 360°.
