I've bought the only gate driver I've found on the local hardware store (IR21531). I want to use it only to drive a IRF630 with a PWM 3.3V signal.
How should I do the wiring? As you can see on the IR21531 datasheet, this chip seems to be intended only to automatically switch two MOSFET at a fixed frequency.
I don't care if I drive the high or the low side.
Also, if this is not possible (as @Respawned Fluff said), could I use any workaround to drive at 3.3V my MOSFET? I need to drive 200V at 5A.
