I have a module that I want to be able to plug into a custom PCB (i.e. not solder directly). The pins of the module are 1mm diameter and would be inserted perpendicular to the custom PCB. What sort of standard sockets exist for this? I have been unsuccessful searching on Digikey and Mouser. The pins are 0.5 inches apart. The module is the following: http://apowerdesign.com/pdf/h30.pdf
\$\begingroup\$ possibly related: electronics.stackexchange.com/q/207230 \$\endgroup\$– Nick AlexeevCommented Feb 4, 2016 at 22:27
\$\begingroup\$ None. Use pin receptacles instead. \$\endgroup\$– Ignacio Vazquez-AbramsCommented Feb 4, 2016 at 22:29
\$\begingroup\$ I would say that, per the dictionary definition of "socket", the answer is not "none", but rather "those sockets exist and are called pin receptacles". \$\endgroup\$– beanCommented Feb 4, 2016 at 23:29
Add a comment
1 Answer
Mill-Max makes a lot of nice pin receptacles for the pin you're citing, for instance
