5
I am learning Fritzing, and looking to create my first pcb. The components are fairly simple: 10x DS18B20, 1x resistor, 1x Konekt Dash. I plan to have headers to connect the Dash so it can be easily removed. When it comes to connecting the 10x temp sensors, I do not know where to start with choosing a connector. The prototype that I have up and running uses a full size breadboard where I used 3.5mm screw terminal blocks for each of the 3 wires for the temp sensors. Lots of wasted space...
How do you go about choosing a connector to maximize space used but ensure it is a simple choice when it comes time to solder to the board and wire up the sensors?
  • \$\begingroup\$ For simple stuff like this, use the Molex KK series, like 22-23-2012 for the PC-mount part. \$\endgroup\$ Commented May 6, 2016 at 14:42
  • 5
    \$\begingroup\$ DON'T USE FRITZING FOR DESIGNING PCBS! IT'S RUBBISH! Use a REAL design tool like Eagle or KiCAD. Fritzing is a toy. \$\endgroup\$
    – DerStrom8
    Commented May 6, 2016 at 15:20
  • \$\begingroup\$ To echo derstrom8's advice, you would do well to use Kicad or (less great IMO) Eagle. Both are considerably more functional. \$\endgroup\$
    – uint128_t
    Commented May 6, 2016 at 23:44
  • \$\begingroup\$ Why would you want to maximize the space used? \$\endgroup\$
    – pipe
    Commented May 7, 2016 at 3:21
  • \$\begingroup\$ As of 2020, KiCad seems the way to go. This will probably be even more true in a few years from now. \$\endgroup\$
    – jjstcool
    Commented May 10, 2020 at 12:27
8
Connectors often seem the hardest choice. If this is for maker or small volumes, I would use something simple, cheap, and easy to get.
I like 0.1inch (0.1") pitch, through-hole header pins and sockets. An advantage of using 0.1" pitch is it's easy to make adapters to both attach cabled devices and also plug into breadboard. So, in your example, you could wire and test your sensors on the existing breadboard or make simple test rigs using stripboard.
Invest in a (modest cost) crimp tool. Then put all of your sensors on crimped connectors.
There are an astronomical number of different connectors. I'd suggest looking at a low cost supplier, with a smaller range like rapidonline. I reason that the stuff they carry is popular, and its easier to see the costs of connectors, crimps and lower-cost crimp tools.
If you use one of the well known, popular, brands (e.g. Molex KK, but there are alternatives and compatible parts) you'll be able to get the connectors from almost any distributer.
You could go for lowest-possible cost 0.1inch pitch pin headers, which can be bought from internet sales sites at quite a low cost (estimate under 0.02 GBP per pin or less). Each wire crimp will be a similar cost, and then the connector socket.
However, it is worth using the more expensive connectors which have polarised connections (extra pieces of plastic which prevent the plug and socket being connected the wrong way round). These reduce the ways that connections can go wrong by plugging in the wrong way round, or shifted sideways. Further, the extra plastic gives a little extra protection from accidentally shorting connections.
These types of connectors aren't as flexible as screw-terminals, but can be much more compact. They come in vertical orientated so many connectors can be packed closely, like servos into a radio control receiver. They are also available in right-angle so they can be arranged around a PCBs edge, and made accessible through the walls of a case.
Edit:
Another consideration is footprints for PCBs. For example, Eagle PCB CAD has libraries of 0.1" pitch connectors, that have been tried and tested, so you won't have to spend time designing footprints. Further, Sparkfun have a useful library which slightly offsets the PCBs holes from an 0.1" grid. The effect is to 'grip' the pins in the PCB while it is being soldered. AFAICT, this took them several iterations to get right. So by using a popular connector you may get some extra unforeseen benefits.
Edit2:
Most of these simple plug and socket systems come in many sizes
For example Molex KK headers, sockets and receptacles are available in 2pin to 36pin connectors.
Another small advantage of using a 0.1" pitch system is you can make a prototype connection on a PCB, veroboard, or breadboard using ordinary 0.1" strip header (which can be broken down to any size) without having the correct pin-size housing to hand. It's feasible to make the wire connectors from a combination of housings because the crimp connector housings stack side-by-side on a 0.1" pitch. So you could make a temporary 5-pin connector using a 2-pin and a 3-pin connector housing. Also it's possible to disassemble a connector by removing the crimped connections from the housing. So it's feasible to alter the sequence of connections in a housing, add or remove connections, and repair connectors. It's handy technology.
  • \$\begingroup\$ I might be missing something, but I only need 3 pins per connection to go to each dallas temp sensor. I like the Molex, but all examples I find are 6 pins. Is that an option? \$\endgroup\$
    – Roger
    Commented May 7, 2016 at 2:20
    \$\begingroup\$ @Roger - Molex KK can have anything from 2 to 36 connections (follow the link in my answer). So, yes, 3-pin is an option. Look at distributers connector pages, e.g. PCB headers, select manufacturer/Brand: Molex, if they have it Series: KK, or Pitch: 0.1" and you'll see them. For example I just searched on RS and got this: uk.rs-online.com/web/c/connectors/pcb-connectors/pcb-headers/… look at the "Number of Contacts", you can see they carry 2pin upto 18pin and beyond. \$\endgroup\$
    – gbulmer
    Commented May 7, 2016 at 2:29
Assuming you want the temperature sensors at the end of a cable:
You need connectors with three pins that ensure correct orientation. Many people simply use Molex connectors because these are common enough that local shops carry them, and there are pre-made cable assemblies.
I'd probably go for the
for the board connectors, and
for the cables. Attaching these terminals to cables takes a specialist tool, which is a good investment if you plan to do more projects in the future), so for a first project I'd probably get some pre-made assemblies.
These have standard 0.1" pitch, so they can be placed in the holes from a standard connector footprint.
  • \$\begingroup\$ I purchased these: amzn.com/B00CHEZ250, 'specialist tool'? - thanks \$\endgroup\$
    – Roger
    Commented May 6, 2016 at 16:01
  • \$\begingroup\$ To all of you: Thanks for the info. Choosing connectors is pure pain, (and the reason why many students drop out of EE at univeristy, pretty sure this is a true fact). \$\endgroup\$
    – jjstcool
    Commented May 10, 2020 at 12:25
