I am currently struggeling with solving the following problem: The circuit below shows a bridge circuit, where the differential voltage between the branches is measured by a differential amplifier. I need to know the relative systematic error caused by using the amplifier circuit.
Given values: $$ R_0=100\Omega \\ \Delta R=1\Omega \\ R=1k\Omega $$
Well, my approach to solve this was to first analyze the bridge circuit itself, then together with the differential amplifier and calculate the relative error by:
$$ \frac{\Delta V_a}{V_a}=\frac{V_{a-amp} - V_{a-ideal}}{V_{a-ideal}} $$
Analyzing the bridge circuit alone: $$ V_D=V_2-V_1=V_s(\frac{R_0-\Delta R}{R_0+\Delta R +R_0-\Delta R}-\frac{R_0}{2R_0})=V_s(\frac{R_0-\Delta R}{2R_0}-\frac{1}{2}) $$
Alright, now analyzing the complete circuit. Well, V_2 is now also applied on the two resistors R, located at the non-inverting input:
$$ V_2=V_s\frac{(R_0-\Delta R) || 2R}{R_0+\Delta R + (R_0-\Delta R) || 2R} $$
But now I am stuck. What do I do with V_1? Because there is actually no ground in the upper branch of the differential amplifier (inverting input). Is my approach as it is correct and my calculations up until now?
