I bought this power supply off Amazon, it is described as 5 Volts DC 60 ampere. I was able to adjust the output so it produces 5 volts at its terminals.
Here is a link to where I purchaed it from:
https://www.amazon.com/gp/product/B017YEOAPA/ref=oh_aui_detailpage_o03_s01?ie=UTF8&psc=1
Internally it consists of a power supply built around a TL494. The design seems typical, but I am unsure how it works. There appear to be two switching components labelled SPYM309. I can't figure out what these are. I expected them to be driven with some sort of signal 180 degrees out of phase with each other, but even using both probes I could not find such a thing.
The other unusual thing is the electrolytic capacitors on the output are rated for 25 volts. The larger components mounted to the case on the left hand side are just two pairs of rectifiers wired as a full bridge.
I know the TL494 internally is two error amplifiers and some other components. I probed around inside the power supply and eventually gave up on trying to figure out what was doing what. I could not even find the +5V from the internal reference regulator on the TL494. I added a single turn of 22 AWG magnet wire to the larger transformer and found this wild waveform. This is using a 2 ohm load. Note that I accidentally had the scope displaying 10x here, but the probe is actually set to 1x
The output waveform seems to just "wander" for about 65% of the time, but the other 50% is spent doing something square wave-ish.
The next test was the same thing, but with a 0.4 ohm load. The scope's setting was 1x, as well as the probes in this capture
The output waveform cleans up quite a bit with the larger load. Interestingly, it still spends about 1/2 of its time around 0 volts.
I have a couple questions about this power supply
- What does the smaller transformer do?
- What are the two switching components?
- Should I expect to find the two switching components in a push-pull configuration?
Any other suggestions on more interesting things to measure with my scope would be appreciated!
