I am powering a small sg90 servo motor (see datasheet) directly using a 12V battery and a simple circuit to step down the voltage to the appropriate one for the servo. I noticed the servo has some coil windings and I suppose I could model it as an RLC circuit.
My question is, how can I know if a flyback protection diode is needed in cases like this? The manufacturer does not seem to care about the inductance since there is no mention of it in the datasheet...
I've already make some brief tests such as a few 90 degree turns and everything went well so far so I guess it is not vital to put such a diode (at least with short usage periods) however I would like to get some enlightment on this topic.
