I want to have the pad that is connected to ground on one component to 'relief connect' on altium but have all other components whos pad is connect to ground to 'direct connect'. Is this possible?
1 Answer
Yes. In the design rules go to Polygon Connect Style and use a query like this:
InComponent(<component with pads in question>) AND InNet('GND')
and set it to relief connect. Put this rule at the top of the priorities, and in the default rule simply have "Direct connect" set.
Relief connect rule (top priority):
"U10" is the component with ground pads that should be relief connect.
Direct connect rule (default, lower priority):
I believe that would work the way you need it to.
\$\begingroup\$ DerStrom8 Thank you, that worked perfectly! \$\endgroup\$– QWERTYCommented Oct 25, 2016 at 16:14
\$\begingroup\$ @JulioSanchez Glad to hear it! \$\endgroup\$ Commented Oct 25, 2016 at 19:16
