I'm working on a project with multiple sensors. These sensors need to be synchronised with eachother as precisely as possible without a physical connection. I need to make sure that if I tell them to start measuring that they start at the same point. If one starts 1 microsecond later than the other then all the measurements will be no use.
Im planning on using GPS to make synchronise the clock rates as being demonstrated here https://pdfs.semanticscholar.org/0529/00a69bbb3db6a615bfb14843a5bcf54292d5.pdf So my GPS synchronises the relative time of the sensors, but can I also use it to synchronise the absolute time? so I can set a t(0) at the exact same time?
