I'd like to create discharging circuit with four LEDs indicating how much charge is left from the discharging battery. It needs to be a low cost solution (no Arduinos; only simple circuit components) I'm not entirely sure how to go about this theoretically; I can only imagine that there would be parallel branches of an LED in series with a resistor. I want each LED to be lit initially and indicate how much of the original voltage/current is left as each LED goes dim:
- 4 lit LEDs = 100-75% charge
- 3 lit LEDs = 75-50% charge
- 2 lit LEDs = 50-25%
- 1 lit LED = 25-0%
- 0 lit LEDs = 0% charge left
EDIT: Let's says it's for a 9v battery
Edit #2: Let's say it's a lithium ion rechargeable battery.
