I am trying to build a wireless battery charger. Below is a rough idea of what I want to achieve.
Currently I am having trouble with the inverter circuit that is shown below.
I understand that this inverter circuit is converting DC to AC by using an H-Bridge configuration with the use of MOSFETS, MOSFET Drivers, timer IC and Inverting IC.
My question is how do I calculate the AC Voltage produced by this inverter if I am to supply 12V DC and set the working frequency to 100khz for wireless power transmission through a litz pancake coil?
I know that regular inverters convert 12VDC to 240 VAC with the use of a transformer. I have tried looking at the 74HC4049N inverting IC datasheet and am unable to identify the outputting AC voltage.
I need to know how much AC is produced in order to correctly build a Diode Bridge rectifying circuit on the battery side.
Any Help will be sincerely appreciated.
