If I want to use a Schottky diode with a forward voltage of 450 mV at 1 A. Is the forward voltage the same at 0.3 mA?
The diode is a 1N5817 and for 10 mA there is Vf=0 V.
If I put this diode in series with a 3.6 V lithium battery in a system consuming 0.3 mA under 2.5 V which is the Vout of an LDO, is my system going to work?
EDIT: This is the application :
