I'm connecting 8 switches on a breadboard, with a common ground (the already-connected line of the breadboard):
Problem: these switches are always on, like if the 2 pins on the common line make them pressed.
I thought that a solution could be to rotate 90° the switches, but then they don't fit on the breadboard anymore (one cannot use the common horizontal line for ground anymore).
I can't believe there isn't a natural solution to connect 8 such switches on a breadboard.
Is there a solution for this?
