Does anyone recognise this connector? It is used as the power connector on a Targus universal laptop docking station. It is 10mm diameter, 4 pins. Similar to but smaller than the one on the right which is a 4-pin Mini-DIN. (The one I bought before I checked the dimensions.)
Mystery Connector on the left
  • \$\begingroup\$ You sure about that? The left one looks like mini-DIN to me and the right one some strange larger variant. \$\endgroup\$
    – winny
    Commented May 22, 2017 at 11:05
  • \$\begingroup\$ Google finds it easily with '4 pin 10mm din notch' image search. \$\endgroup\$
    – user133493
    Commented May 22, 2017 at 11:07
    \$\begingroup\$ Does this look like it? mouser.com/ds/2/222/KPPX-365228.pdf \$\endgroup\$
    – Tut
    Commented May 22, 2017 at 11:42
  • \$\begingroup\$ @winny - Thanks. The one on the right is what I got when I ordered a 4-pin mini-DIN from ebay. \$\endgroup\$ Commented May 22, 2017 at 11:57
  • \$\begingroup\$ @Tut, you should make an answer instead of a comment. \$\endgroup\$
    – Jeroen3
    Commented May 22, 2017 at 12:24
It looks like a typical power plug on high-powered laptops, Such as Alienware, Acer or Clevo. It appears to be called "DIN-4pin".
    \$\begingroup\$ Thanks. @tut above pointed me to the plug, which is what I'm looking for. \$\endgroup\$ Commented May 22, 2017 at 12:02
