Here is an assignment: to determine gm, internal resistance at the drain, and maximum gain (μ).
  1. Can transconductance gm be found from the formulas and graph?
  2. How to determine graphically the internal resistance at the drain? As I understand it, it is: r'ds = delta V(DS)/delta I(D). How to determine the delta V(DS) from the graph?
  3. In the end it is: A(v) = gm*r'ds. But how to determine μ with the given data?
  • \$\begingroup\$ Resistance should be voltage divided by current. So it can't be \$\Delta V_{ds}/\Delta V_{gs}\$. \$\endgroup\$
    – The Photon
    Commented Jun 13, 2017 at 21:15
MU at 6 volts drain is just [Id(Vgs = 0.6v) - Id(Vgs = 0.2v)] / (0.6v - 0.2v), or
(13.5ma - 6.5ma) / 0.4v = 7ma/0.4 = 7ma*2.5 = 17.5mA/volt
  • \$\begingroup\$ but this is the calculation of gm (transconductance), not mu (gain) \$\endgroup\$
    – Tomas
    Commented Jun 14, 2017 at 11:38
  • \$\begingroup\$ gm and rd are Norton's equivalent. Mu is what you get if you turn it into Thevenin's one i.e. mu=gm*rd \$\endgroup\$
    – carloc
    Commented Jun 14, 2017 at 12:01
  • \$\begingroup\$ yes, mu = gm*rd. But "[Id(Vgs = 0.6v) - Id(Vgs = 0.2v)] / (0.6v - 0.2v), or (13.5ma - 6.5ma) / 0.4v = 7ma/0.4 = 7ma*2.5 = 17.5mA/volt" - is the clear calculation of gm. delta Id / delta Vgs \$\endgroup\$
    – Tomas
    Commented Jun 14, 2017 at 13:51
