I am planning to connect (at least) two Raspberry Pi + PiCAN2 shields via CAN.
I think I understand the concept of a daisy-chained multidrop CAN line, but what about using the 120 ohm resistors for termination that are provided on board by the PiCAN2 shield?
As far as I understand when I simply connect CAN High and CAN Low respectively between both PiCAN2 shields A and B as shown below, I should use the 120 ohm resistors on both sides for termination. Am I right?
What happens when I add a third identical node (Raspberry Pi + PiCAN2 shield) C to the CAN bus? Do I need to terminate also on this node? As I can without problems also use the terminator on C, is there any drawback to using the 120 ohm resistor on all nodes, not worrying about the geometry of the network?
A
toC
toB
without a stub atC
..... with a long stub, it would not be a daisychain, but it would be a star network \$\endgroup\$C
. Would this require a terminator? \$\endgroup\$You don't have a Star network as shown
... there is no mention of the length of the stub atC
.... if it is long then the network is a star network and requires termination atC
