Data sheets often give uncertainty in dB. If uncertainty is specified as a percent, I believe that means it is a relative uncertainty. Assuming the coverage factor is one, the relative standard uncertainty is the percentage given. When uncertainty is specified in dB and is converted back to a percentage, the interval is no longer symmetric. For example, +/-3 dB would be +100%/-50%. How should I interpret this?
Edit
In The Measurement of Power Spectra by Tukey and Blackman, the interval is given as the spread in dB. "Spread is the difference between the upper boundary expressed in db, and the lower boundary expressed in db." And "All intervals are symmetric in the probability sense, half of the non-included probability falling above and half below the interval."
If we think of the interval in terms of total spread, does it make sense to add the positive and negative uncertainties? For example, +/-3 dB, would be a spread of 6 dB or +/-150%.
