Consider the following circuit:
Now I'm asking to impose the base current as zero and $$R_C=452.35 \Omega $$
Now I have a lot of issues with this circuit because I can't find a systematic way to approach this.
Here is the work I've done and problems I found:
1) ASSUME ACTIVE ZONE ONLY USE KIRCHOFF'S LAWS
We are told to neglect the junction voltages when the junction is directly polarized so I should neglect \$U_E\$
Now from Kirchoff laws we will obtain: $$I_C=I_E$$ $$U_C=-E_C +R_CI_C$$ $$0=E_B +R_EI_E$$
which leads us to $$I_C=60 mA$$ $$I_E= 60 mA$$ $$U_C=-2.859 V$$
which makes me accept my hypothesis... However if I try now to apply Ebers-Molls equations I get to
$$I_C=\beta I_B + I_{CE0}(e^{\frac{U_C}{u_T}}-1)$$
I obtain $$I_C= 10 \mu A$$
So something is terribly wrong with this approach. Is anything wrong with my equations. My suspect is that I'm wrongly substituting the resistor as a short-circuit to apply Kirchoff laws. Since current is zero I should instead substitute it by using an open-circuit? I never quite understood this resistor paradox from circuit analysis:
Zero current is equivalent to an open-circuit ´ However zero current means zero voltage across resistor from Ohm's law which means a short-circuit.
I think that might be what I'm messing up here. Can someone clarify me please?
