Do anyone can tell me how to get amplification equation for this circuit of coupled common emitter amplifier?
Edit 1
Equation for single transistor only with corresponding circuit.
common emitter amplifier equation common emitter amplifier circuit
    \$\begingroup\$ Are you able to analyse a common emitter gain stage with one single transistor only? \$\endgroup\$
    – LvW
    Commented Feb 8, 2019 at 15:29
  • \$\begingroup\$ Ok. I understand, you want to check if I'm not just lazy dude. Answer for your question is in Edit 1. @LvW Do you can help me now? \$\endgroup\$
    – user19291
    Commented Feb 8, 2019 at 15:54
    \$\begingroup\$ @user19291 No, LvW wants to guide you towards the answer rather than just giving it to you, because that's a much more effective way of learning. \$\endgroup\$
    – Hearth
    Commented Feb 8, 2019 at 15:57
    \$\begingroup\$ What's is best for depends on person. In my case best effects are when I can analyze an example. I have some in books and for some I ask around the Internet. I'm not 15yo who ask for doing his homework I want to understood how it works and answer for my question will be very helpfull for ME. Thanks \$\endgroup\$
    – user19291
    Commented Feb 8, 2019 at 16:04
  • \$\begingroup\$ Try read this electronics.stackexchange.com/questions/390192/… Is this help you or not? \$\endgroup\$
    – G36
    Commented Feb 8, 2019 at 17:17
