Given are two signals A and B. I want to control the connection between them by a signal C. However, signal C is a logic signal with a voltage of 3.3V for high and 0V for low whereas signals A and B are at a level of 4V.
How can this be done? Using a Mosfet with C as gate and A and B as Drain or source, respectively will not work as C would have a lower voltage than the source. Therefore, the difference G - S would always be negative.
