I'm making a pedal from this tutorial https://www.instructables.com/id/Overdrive-Pedal/ and the author is using this type of jack female connector:
But I already bought this type of connector:
The author's connector has 3 tabs to connect, and in step 13 he said:
"Connect the black wire from the 9v battery snap to the remaining unused tab on the stereo jack."
But I'm an amateur and I do not know how this connector works. I already used the 2 tabs to connect other wires, and there's no tab left. Is there difference to connect all wires to the same tab, or are these tabs only a method to organize my wires better?
Will this connector still work (in my case) when the connector has only one tab and I connect all wires in the same tab?
