I'm using the circuit in the picture as a replacement for a mechanical relay running a 40 W, 220 V water pump.
The problem is that although the circuit seems to be correct, it doesn't work, and I'm getting a weird result on the multimeter.
When monitoring the AC output of the circuit with a multimeter, it shows 220 V when the logic input of the moc3042m is low. Also, this voltage doesn't turn on the pump. When changing the logic input to high (5 V), the output doesn't change.
- The actual pump is connected to the
J4
terminal. - The
Pump
label in the picture is for the logic input.
If you see any problem in the schematic, please explain it.
