I have two statements here from two great men.
One says
"If you apply AC voltage to the solenoid at the peak of the waveform then there is little or no inrush current whereas if the solenoid is connected to an AC source as it passes through zero volts then the current waveform in the solenoid can reach an excessive value that causes magnetic saturation of the solenoid core and make the problem of inrush even worst"
other one says
"The transient depends upon the contact timing referred to the AC voltage applied, if the contact happens at any AC voltage peak, there is no transient at all (the current becomes a 90 degrees delayed wave straight away) while the transient will be maximized when the contact is achieved at any AC voltage zero crossing, the superimposed current will looks like an asymmetrical Gauss bell (very steeply at rising side)."
My question is why there is transient current or inrush current when a ac source is connected to an inductor at ac voltage zero crossing and why is there is no transient at ac peak voltage ?
