In my cabin I have a sollar cell and a 12V battery that I use to power my electronics. However I'm dissatisfied with the standard CL sockets used in cars (apparently I'm not the only one) and I decided to reuse a foreign AC socket instead, specifically the United Kingdom's “13 amp socket” (BS 1363).
I chose the UK socket because it's well designed and it's very rare that anyone has UK plugs in my country. I will take actions to ensure no-one will thoughtlessly plug an UK electronic device to these sockets!
The socket is designed for 230 V and up to 13 A of alternating current. That means it can supply up to ~3 kW of power. However with the 12 V I'll be using, thirteen amps can barely reach 150 W. Since some popular water pumps need ~700 W, this seems like a serious limitation.
In a different question here on Electrical Engineering SE, someone asked whether they can use a 10A@250V-rated socket to draw 13A@230v and the most popular answer says that “the only important parameter is the current rating, [...] 10 amps through the socket will heat it up just as much at 1 volt as it will at 5,000 volts.” Sadly, they don't provide an explanation why. Does this apply to my case and why / why not?
Another thing that concerns me is I'll be using DC instead of AC. There are several things that work differently with direct and alternating current. Is it safe to use the socket this way?
EDIT: There is a question about the current rating of fuses where they explain why fuses blow at a certain current, not power. However I failed to understand the reasoning in the answers, so I can't tell whether it also extends to my case, or not.
  • \$\begingroup\$ the only important parameter is the current rating - is pretty much correct. And the explanation is given. The power that is droping on contacts is \$I^2 R\$ - and as you can see is not depending on the voltage. \$\endgroup\$
    – Eugene Sh.
    Commented May 11, 2020 at 17:33
    \$\begingroup\$ Yes, this applies to your case. In fact, in general, you can use a socket for less current with DC than you can with AC. Consider a proper high-current DC connector, like an Anderson powerpole or something. \$\endgroup\$
    – Hearth
    Commented May 11, 2020 at 17:34
    \$\begingroup\$ @EugeneSh. But why is it \$I^2 R\$ and not eg. \$I U\$? \$\endgroup\$
    – csha
    Commented May 11, 2020 at 17:43
    \$\begingroup\$ @m93a Because \$U\$ on a conductor depends on the current. And it is reflected in the formula: \$P = I\times U=I\times I\times R = I^2\times R\$ \$\endgroup\$
    – Eugene Sh.
    Commented May 11, 2020 at 17:44
    \$\begingroup\$ "But why is it I2R and not eg. IU?" It is \$IU\$ but it's the voltage across the contact resistance, not across the load! \$\endgroup\$
    – Transistor
    Commented May 11, 2020 at 17:59
4 Answers 4
Power is current times voltage (P = IE). You don't mention if you're converting from one voltage to another. Are you using a step-down converter? Are you merely charging the battery with the solar system and want to know how to achieve equivalent power from a charged battery bank?
230V AC 13A is 2990 watts. 2990 watts at 12V DC would be ~249 amperes. This means your battery(ies) (and all the connectors and cabling) would have to be capable of safely delivering 250A in order to have roughly equivalent power to your UK mains example.
Because you said "13A at 12V can barely reach 150W" it seems like you're already aware of the relationship between voltage, current, and power. It also sounds like you're looking for a better socket to use for your system, and chose the UK mains style because it won't likely be confused with the real thing.
So here's what you are maybe missing, related to my question from 8 years ago about fuses. Voltage is what "motivates" electrons to go through a particular thing, whether it's a fuse, a wire, or a connector. The current is "how many" of them. The larger the current, the greater the friction, and thus heat. A connector or wire rated for 13A is not going to handle more power unless the voltage is also higher. In the case of a connector, the voltage rating will be mostly applicable to the distance between conductors (to avoid arcing) while the current rating will be applicable to the robustness of the conductors.
Put another way, 13A can have wildly different power values based on voltage, but it's always going to be the same quantity of electric current flowing. If the voltage is 12V, you're right, it isn't a lot of power, but it still requires thick wire and connectors to safely handle that current without having an unsafe temperature rise.
You will likely want to use something capable of much higher current. Automotive applications that use 12V systems often have fuses and wire rated for 50 or more amps. But be absolutely sure to look at the specifications for your battery (or battery bank). There's no point in installing 60A-capable wiring and connectors if your source can only supply 40A. Also be sure to install fuses to limit current to less than the weakest link in the system.
From your comment:
It's because the plug contacts know nothing about the voltage of the circuit. All the contacts know about is the current through them and the contact resistance. The voltage on the load is irrelevant as far as the contacts are concerned.
Figure 1. A Schurter C20, 16 A plug. Image source: RS Online.
I couldn't find a specification for a 13 A plug but the C20 plug has a contact resistance of < 10 mΩ according to RS. At 16 A the power (heat) dissipated in each of the live and neutral pins would be given by \$ P = I^2R = 16^2 \times 0.01 = 2.56 \ \text W \$ or 5 W for the feed and return. This is not insignificant.
Note that the voltage across the load doesn't enter into the calculations. Current is what matters.
Figure 2. Something like Anderson Power Products Powerpole connector series may be more suitable.
  • \$\begingroup\$ Thank you for the explanation and advice, Anderson Powerpole are well suited for the voltage and current I'd be using. However I'm looking for a wall socket. Could you recommend a wall socket capable of such high currents? Thanks again! \$\endgroup\$
    – csha
    Commented May 11, 2020 at 19:12
A main point regarding current and voltage: more current produces more heat. Current is the pseudo-actual electron flow (https://www.chegg.com/homework-help/definitions/current-flow-2) and the reason power lines use very high voltage and little current (to minimize losses due to heat). http://www.betaengineering.com/high-voltage-industry-blog/transmitting-electricity-at-high-voltages NOTE: the electrons actually move relatively slowly, it's the energy itself that moves at near the speed of light.
As for the ratings of the device, it is never a good idea to exceed either limitation. However, many devices have specifications lower than their theoretical maximum due to variability in manufacturing. I am in no way recommending to find out their max specs though.
I would see if there is a way to use a power transformer to step up the voltage to the rating of the outlet to deliver more power at approximately the same current. With your current 12vDC, there is no way to deliver ~700W at only 13A.
    \$\begingroup\$ What do you mean by "the pseudo-actual electron flow"? I'm not really sure what your first sentence is trying to say either. More heat than what? \$\endgroup\$
    – Hearth
    Commented May 11, 2020 at 17:35
-3
I disagree with the one answer. Been a life long power enthusiast, and have my degree from MIT. So voltage carries the current. Like a water main. The larger the flow the better the water can get to where it needs to be. DC is difficult because it doesn't really apply to common knowledge about circuits. DC mostly traves on the outside of the wire. Similarly to RF. While the electrons flow inside of the wire with AC. You would be best to, depending on your situation. Install "buss" bars in your cabin. Then run leads off the buss bars to power your intended power needs. That way nothing is wasted. DC doesn't work for distance. Hence the reason we use an AC grid, not to mention AC is easy to convert voltage. DC won't work on a transformer! But for small applications, don't convert it. You'll always experience loss when converting ac to DC or DC to ac. So, look for 12v stuff. Get it connected to the battery bank with the biggest copper you can and you'll probably be ok. Always remember, heat is because of resistance. If something is hot, your loosing power. So make it bigger. DC is all about how big the "water line" is. Not the pressure. The pressure is the current.
    \$\begingroup\$ You seem to have several things backwards. Skin effect applies to AC, not DC. The usual hydraulic analogy is that pressure is voltage, while flow rate is current. I'm not sure what you mean by "DC is all about how big the water line is"; that's just true in general, regardless of whether it's DC or AC--a larger wire can carry more current. \$\endgroup\$
    – Hearth
    Commented Oct 3 at 0:11
    \$\begingroup\$ Also, you get more loss in a typical mains transformer than in a well-designed DC-DC converter. It's just that mains transformers are easy and low-maintenance. Also, what answer do you mean by "the one answer"? The question has three answers other than yours. \$\endgroup\$
    – Hearth
    Commented Oct 3 at 0:13
  • \$\begingroup\$ "DC doesn't work for distance." Yes it does. Very long and undersea power transmission lines use DC because of its lower losses than AC (and the savings make the AC/DC and DC/AC conversion worth the expense). "So voltage carries the current." No, voltage drives the current. Welcome to EE.SE. Remember that you can edit your answer to improve it. \$\endgroup\$
    – Transistor
    Commented Oct 3 at 1:45
