Situation
- I need 2 kHz -10/40 V square wave duty <1 % pulse to drive 50 ohm load.
- I have a working 0-40 V solution: PWM by MCU driving a N-MOSFET low side switch off a 40 V DC rail.
Questions:
- Is it possible to somewhat shift the voltage to negative after MOSFET output (low side is tricky, no common ground)?
- If not, what is the most practical way to produce such pulse?
