I have some doubts regarding 2.4 LCD TFT ( NHD-2.4-240320CF-CSXN ) backlight current limit resistor value.
Datasheet note is not clear
6. Backlight: White LED / 3.1V / 100 mA ( Typ )
3.1V means:
a) backlight LEDs forward voltage ? or b) expected backlight source voltage ?
I assume this means LED forward voltage. Then, when powering backlight from 5V source the current limiting resistor should be (5V-3.1V) / 100mA = 19 ohms Is that right ?
Thank you
