I am attempting to drive an STP55NF06 N-Channel MOSFET with a TC4427 gate driver, switching at ~100kHz. The desired outcome is a higher current PWM square wave at the MOSFET's drain (Circuit in Figure 1).
However, my actual implementation of the circuit doesn't behave as it does in simulations (where there is just a normal square wave at Vout). The Vout in the physical implementation is shown in Figure 2 as a pink trace, with the yellow being the driver's voltage level. The Vout has a difficult time reaching the rail's voltage. The problem seems to be the time the driver is taking to make the MOSFET conduct as a higher PWM duty-cycle or lower frequency switching speed always means a slightly better waveform. A smaller current-limiting resistor helps, but only the slightest bit, and 10 ohms is close to the lowest this driver can go at 12V.
My real confusion lies in the fact that switching the pull-up resistor R to the other side of the MOSFET and measuring the voltage between the (now pull-down) resistor and source terminal shows a nearly perfect square wave. The resemblance between that voltage waveform and the driver's voltage is nearly the same, making me think the problem is not the current delivered to the gate.
To give some context to this problem, I have been attempting to create a Class D amplifier, but I have run into a roadblock with the output stage. This question has abstracted out a bit, but the problem is essentially that I do not know why an n-channel MOSFET isn't working here. I anticipate that the answer is that I am misunderstanding the way that an n-channel MOSFET works, but I am not sure in what way.
