My textbook has the following example of hypothetical linear motor.
A current carrying conductor is placed in a magnetic field.
The conductor is attached to a variable load(pulley+weight).
How it works:
The force of variable load(pulley+weight) is toward right.
The magnetic force (q\$v \times B\$) is toward left.
When there is no load, the conductor accelerates toward left; the back emf grows; when the back emf reaches the supply voltage, current becomes 0, acceleration becomes 0; then the conductor moves at this maximum constant speed.
When the load is increased, the conductor decelerates, back emf decreases, current rises, the magnetic force increases. When this magnetic force balances the load, the deceleration stops; then the conductor moves at this reduced constant speed.
Good so far.
Question: My textbook says that when the resistance of conductor is 0, the speed remains constant at maximum speed no matter what the load is. I don't get this. How can speed not change with load? When we increase the load, surely the back emf decreases. This means the flux linkage is less; this means the speed of the conductor is decreased. I don't see how resistance of conductor plays a role here. Help?
