My project involves mounting an ultrasonic transducer on a shaft rotating at >1000 RPM. What possibilities exist to supply power to the transducer?
I cannot use slip rings because slip rings need to be permanently fixed on the shaft and in this case, the shaft needs to be taken out of the assembly on a regular basis. I would be really grateful if you could give me some suggestions. The accessible area of the shaft is around 10-15 cm.
