I'd like to connect the output of my software defined radio card, which is 50 ohms SMA, to the antenna input of a TV, to experiment a bit with signal generation.
The obvious problem is going to be the impedance mismatch, but that can be solved with a resistor network or a transformer.
Friends have mentioned that TVs often have a DC supply for antenna amplifiers, which would rule out the resistor network, and also the transformer, as that would short the supply voltage.
Is there anything else I might have missed that I'd need to know to protect my (rather pricey) SDR card?
