One thing that approximates a constant power load is a switch mode power supply with a fixed load on the output. The power supply converts variable voltage input power to fixed voltage output power and supplies that to a load.
For example, if you had a buck converter that puts out 100 V, and you connect a 0.11 Ohm resistor to it, it will put out 900 Amps. So it is delivering about 90 kVA to the resistor. If it also dissipates 10 kVA in lost power, that means it will consume 100 kVA from the input supply.
So our theoretical buck converter with a resistor as a load on the output is similar to a constant power load.
If I supply the buck converter with 1000 V on the input, the output will still be 90 kVA. The input power will still be about 100 kVA.
In reality, though, buck converters that can accept a 10:1 input voltage range are unusual. And even if they can accept such a wide range, the efficiency will usually not be consistent across the full input voltage range. Generally efficiency tends to go up as Vin is closer to Vout. So the buck converter approximates a constant power load, but has some variation of power with voltage.
Also, 100 kVA is a high power level for a buck converter. Certainly I have zero experience designing something like that. I suspect it is possible, but it is outside my experience.
There is also something called an electronic load or programmable load. The ones I have seen are usually lab bench units. They have different modes of operation, but if you set it to act as a constant power load, it will monitor input voltage and current, and adjust the input current to maintain the target power level. Again, given the 10:1 voltage and current ratio on the question, you would likely need a massively over-sized electronic load (rated at much more than 100 kW).
I am sure there are applications for 100 kW programmable loads, but they would be somewhat specialized. You probably can't find a price list with model numbers and just order it online. You would need to contact the supplier and discuss your needs to work out the details.
In both of these cases, the way the load would work is by using current control in conjunction with sensing of voltage and/or current at the input and/or output of the module. It would not be just a "dumb" load.
There are probably other ways to approximate a constant power load, but they are all going to involve some type of feedback so that the input current naturally goes down as the voltage goes up.
