Consider a voltage in a circuit(say 100 V) in a closed circuit, and a resistor 10 ohm and a Load of 20 ohm connected across it. when you turn on the switch, current through them is almost 100/30 (3.33~ A). but when you increase the Load (say instead of 20 ohm, 40 ohm, the current now is 2 A.
but usually when the Load increases, we say it draws more current. how??
