When it comes to validating a power supply (for example, a buck regulator), what parameters matter?
From the research I have done, I think that things such as ripple voltage, percentage overshoot during load step, and thermal performance all matter - what else should I be monitoring/recording?
    \$\begingroup\$ Have a look: oeg.co.jp/en/semicon/power-s.html \$\endgroup\$
    – Mike
    Commented May 16, 2022 at 5:40
    \$\begingroup\$ Efficiency should almost always be on the list of things to check. \$\endgroup\$
    – Hearth
    Commented May 16, 2022 at 5:46
    \$\begingroup\$ Temperature of the obvious bits under worst case conditions. \$\endgroup\$
    – user16324
    Commented May 16, 2022 at 11:39
First of all, you should have a design spec document which should definitely have:
  • Input voltage range
  • Output voltage (accuracy, tolerance and, if required, adjustment range)
  • Output power (continuous, peak and other ratings at different inputs)
  • Efficiency (may not be constant and may be given for different conditions)
  • Ripple and noise limits
  • Line regulation and load regulation
  • Environmental conditions
  • Protections with definitions of expected behaviour (e.g. OVP latch, OLP hiccup, OPP latch, etc.)
  • Applied standards and regulations if required (This includes electrical, mechanical and chemical stress)
NOTE: These all apply to a PSU regardless of that if it's an off-the-shelf or a designed-from-scratch.
Then, you can validate the PSU according to the specified requirements.
This is defined under dynamic response and dynamic response should be defined well-detailed. The requirements may vary depending on the design but generally, allowed percentages of overshoot and undershoot during different load steps (i.e. 0 to 100%, 100% to 1%, 1% to 50% etc.) with different slew rates (e.g. 1 A/μs) are defined under dynamic response. Sometimes settling time is also a requirement. But what you absolutely don't want to see is oscillation. In some case you may want to measure the loop response with special equipment.
