I've set up a power supply using a MAX632 DC/DC Boost converter to bring up voltage from a small 4.5V battery, then I'm using a LM2940CT-5.0 linear regulator to bring it back to 5V, which the voltage the rest of my circuit is designed for:
I wired the power supply according to the respective datasheets of LM2940 and MAX632:
- The 330µH inductor L1, and the C1 and C2 values are the same as in the typical application provided in the MAX632 datasheet.
- The R1/R2 voltage divisor and C3 are to adjust the
Vout
voltage, and also come from the MAX632 datasheet. - C4 and C5 are the recommended values I found in the LM2940CT datasheet.
Everything works like a charm... on average: I've got the right supply even with a dying battery, but I also get a high frequency noise that comes from the switching converter.
The question
How can I block this noise? Or, even better, is it possible to prevent the buck converter to produce it?
I found a possible duplicate of my question here, but there is no actual answer: How do I get rid of switching noise from these types of DCDC converters?
I work at home, so I'm looking for some good practice that I can apply without involving myself into some high technology nightmare that would led me out of my depth.
This is what the prototype looks like for the moment. I've highlighted the area where the DC conversion is:
Noise measure
In the two pictures below, the yellow trace is measured at Vout
and the blue trace is measured at Vreg
- Picture one has a horizontal scale of 5us/div and shows the switching noise pounding at a rate of 10 us (100 kHz). The amplitude of the noise is the same in both measures, approximately 500 mV:
- Picture two shows the same two signals, but with a horizontal scale of 10 ns/div. The switching beats are ringing at a period of 1.5 horizontal divisions. At the selected scale this translates into a period of 15 ns (66 MHz) :
Of course, 66 MHz traverse the linear voltage regulator like if it was not there.
Solutions that don't look good
I thought of two solutions, but neither seem doable:
- 1st solution - A low pass filter with a cut-off frequency around 5 MHz
- 2nd solution - A choke inductor of 66 MHz
Low pass filter
I could place a 4th order filter with twice a LC pair and a dampener after the second pair for this design:
Following R. Künzi Passive Power Filter procedure, if I base my design on available inductors like the B78108E1221M000, which has 220 nH, then I can obtain a cut-off frequency of 5MHz using capacitor values between 1nF and 10nF.
The inductor self resonant frequency is 610 MHz, well above the noise I want to cancel. This seems appropriate.
Capacitors of 10nF or less are available in COG dielectric, which is compatible with high frequency. However high, COG dielectric self-resonance is around 20MHz (see page 9, COG dielectric) which is below the noise frequency.
For the above reason, I don't believe this filter will cancel my noise.
A choke inductor
Much simpler than a low pass filter would be inserting a single choke inductor of the right resonant frequency like this one:
- AIAP-01-5R6K-T
- 5.6 µH Unshielded Wirewound Inductor 1.6 A 74 mohm Max Axial
- Self resonant frequency: 64 MHz
But... I've got the feeling that this 66 MHz is the outcome of some complex interaction between the input inductor of the boost converter, its internal switching scheme, and the output capacitors C1 to C4. So, I fear that placing a choke there would move the frequency to some other that can pass the choke.
Edit: Some comment suggest that the 66MHz frequency may also involve the other parasitic capacitances / inductances that are distributed everywhere in this very loose layout made out of wires. To verify it, I've replaced the load of the voltage regulator by a single 150ohm resistor, and left unpowered the whole circuit. This did not change the noise amplitude or the resonance frequency.
vout
, both positive and negative? \$\endgroup\$
