Besides the problem with the sweep range already mentioned, your values look odd.
You have a rather large capacitance and a rather small inductance.
When you run the sweep you're going to find that there is a lot of loss at the center frequency, around 14 dB. If you reduce the capacitance and increase the inductance you will reduce the loss. The trade off is that the bandwidth will be increased.
You can try dividing the capacitance by powers of 10 and multiplying the inductance by the same value. For example now you have 1000 uF and 25 uH, try 100uF and 250 uH, 10 uF and 2.5 mH, or 1 uF and 25 mH and see how the L to C ratio affects the results.
